Date/Time: Mon, 20 Jan 2025 11:12:10 +0000
Time difference
View Count: 1066
[2018-06-15 13:56:21] |
User13176 - Posts: 6 |
Why would there be a 30 sec difference between "time and sales" and the time on the chart? Es 1 min chart using CQG data.
sc time diff.PNG / V - Attached On 2018-06-15 13:50:25 UTC - Size: 36.19 KB - 281 views Attachment Deleted. |
[2018-06-15 16:35:20] |
You are making reference to the Countdown Timer study. Refer to this section here about this: Countdown Timer: Inaccurate Countdown Time Value or Amount Remaining | Countdown Time Not Changing Also make sure that you are not using the local computer clock for time stamping: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating: Using Local System Clock for Timestamping Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-15 16:35:57
