Date/Time: Mon, 20 Jan 2025 11:09:19 +0000
draw dom graph on chart
View Count: 1723
[2018-06-15 13:34:36]
Glenn Infinity - Posts: 103
draw dom graph on chart (char settings, advanced settings 2 tab) is there any way to narrow the range?
is there any way to apply an indicator or do a percentage more focused on first 5 prices out as an example?
[2018-06-15 16:30:11]
Not totally sure what is meant by narrow the range. Do you mean the number of price levels, or do you mean the horizontal width?
The market depth data can be accessed through a Spreadsheet and then you can do calculations. Refer to:
Depth of Market Data
[2018-06-15 16:33:49]
[2018-06-15 18:07:14]
This cannot be controlled. But do refer to the study we referenced in our prior post.
