Date/Time: Sun, 24 Nov 2024 08:46:21 +0000
Compiling cpp file
View Count: 2406
[2013-10-14 12:31:52]
ABeyer - Posts: 10
I got a cpp file from a developer and could compile it and run the indicator on my notebook. On my desktop PC, I can start the compiler but the file is not saved in the data folder. Both computers run on Windows 7, same Sierra version. What could be the problem?
This is the message I get - no file is saved in the Data folder
-- Starting build of Custom Studies Source File: AB_Retracement_1.cpp. -- 14:27:21
"C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\Program Files\ACS_Source\AB_Retracement_1.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\Program Files\Data\AB_Retracement_1.dll"
-- End of Build -- 14:27:22
[2013-10-14 17:50:59]
The compilation has been successful. We see you are using the Windows Program Files folder. Do not use the Program Files folder either for Sierra Chart or for data. You will only create problems like this that we do not provide support for. Refer to this section here about this:
https://www.sierrachart.com/index.php?l=doc/download.php#download
[2013-10-14 20:06:30]
ABeyer - Posts: 10
I reinstalled Sierrachart, but it did not help. I just saw that User 14383 has the same problem - no file is being created in the Data folder.
-- Starting build of Custom Studies Source File: AB_Retracement_1.cpp. -- 22:01:20
"C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\AB_Retracement_1.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\AB_Retracement_1.dll"
-- End of Build -- 22:01:21
[2013-10-15 05:55:08]
We have run a test and did not see a problem. So we have deleted the compiler and we are reinstalling the latest C++ compiler to see if there is an issue with it.
[2013-10-15 07:03:10]
ABeyer - Posts: 10
The strange thing is the compiler runs fine on my notebook, but not on my desktop. So the compiler works, but for some reason it does not save the file
[2013-10-15 07:49:21]
We have confirmed this is a problem with the latest MinGW port of the GCC compiler. We are seeing how to get the prior version of it. We have also communicated the issue on the appropriate mailing list.
[2013-10-15 15:40:43]
ABeyer - Posts: 10
It works also with me - thank you for the fix!
[2013-10-15 22:52:37]
We have confirmed the problem is now resolved. Let us know if you need further help.
First time we have ever seen a problem like this. It is not clear as to what the problem was. We have provided further details to the developers. Apparently though, they have fixed it.
