Date/Time: Mon, 20 Jan 2025 11:14:31 +0000
Alerts
View Count: 666
[2018-06-15 02:53:58] |
Trader&Hunter - Posts: 131 |
How do i set a price alerts to get email, audio alerts and text message? I am wanting to set alerts at certain fib levels. Thank you
[2018-06-15 14:19:25] |
John - SC Support - Posts: 37327 |
In terms of placing the alert, you can use the Symbol Alerts. The documentation is here: https://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#AddSymbolAlert Or, if you are using a Drawing tool for the fib levels, then you can use the Drawing Tool Alert. The documentation is here: Chart Drawing Tools: Chart Drawing Alerts In order to setup the alerts including email and text messages, refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#Tab_General3 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-15 16:08:42
