Date/Time: Mon, 20 Jan 2025 11:15:35 +0000
A workaround for SC not putting charts in the order that is selected
View Count: 622
[2018-06-14 23:05:55] |
User432504 - Posts: 73 |
Hello SC: I have found a workaround for SC not keeping and displaying the correct order that the charts are set to under Window > Windows and Chartbooks > Windows. I have ordered my charts using the above path and when i open SC, the charts are displayed in some type of random order, if they are detached from the main screen. However, rather than having to re-attach the out of order charts and then detach them again in order to get the charts in the order i desire, I have found that if I just open another chartbook and then go back to my first opened chartbook, the charts will be in the order i chose under Window > Windows and Chartbooks > Windows. I will send you my software testing and fix bill, SC. :=) If you want to hire an excellent software tester, just let me know. Lemme guess....this is all Windows fault. Thanks for your stable charts. |
[2018-06-15 18:28:16] |
Lemme guess....this is all Windows fault. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-15 18:29:24
