Date/Time: Sun, 24 Nov 2024 08:18:11 +0000
Bar made from Pullback calculation // Pullback information in "Numbers Bars Calculeted Values"
View Count: 1706
[2013-10-14 12:14:35] |
Moti - Posts: 63 |
Hello SC support, Please Insert Pullback info into "Numbers Bars Calculeted Values" it will very helpful and easy to watch them via a table. - - - Please advice if you get a request of pullback Bar / or study and I can find this on the site From every New Low recount ASKV- BIDV, if ASKV- BIDV equal to (250) Green bar open a new bar From every New High recount ASKV- BIDV, if ASKV- BIDV equal to (-250) Red Bar open a new bar Thank you, Moti |
[2013-10-15 02:42:43] |
You need to set the Show Pullback Column Values Input to Yes with the Numbers Bars Calculated Values study. Refer to the documentation here: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#CalculatedValuesInputDescriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-15 02:43:38
[2013-10-15 16:27:57] |
Moti - Posts: 63 |
Please Check again, Not active Show Pullback Column Values: When this input is set to Yes, then the Pullback column values for each of the displayed calculated values rows will be calculated and displayed. The pullback column is displayed after the very last bar in the chart. |
[2013-10-16 02:49:53] |
It works. Did you scroll past the last bar in the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-16 02:50:10
