Date/Time: Mon, 20 Jan 2025 11:28:20 +0000
Unable to connect SC to IQFeed
View Count: 734
[2018-06-14 22:25:14] |
User842104 - Posts: 3 |
Hello, I am trying to connect sierra charts using IQ feed but it says IQFeed not enabled on this package, see attachment. can you help me wwith you. Thanks |
6-14-2018 3-16-39 PM.jpg / V - Attached On 2018-06-14 22:24:02 UTC - Size: 128.37 KB - 315 views Attachment Deleted. |
[2018-06-15 18:09:25] |
You need a direct account to be able to connect to IQ Feed: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
