Date/Time: Mon, 20 Jan 2025 11:20:08 +0000
Value Format on Study Subgraph as Text Above/Below Bar
View Count: 743
[2018-06-14 19:07:06]
First, we recommend you update to the latest version of Sierra Chart, as there is a new version of this study that makes it easier to work with for what you want to do. You can update following the instructions here:
Second, you need to reference data that has the difference between the high and low, as you have seen, the Main Price Graph does not have this data. Therefore, you need to use a study that does have this information, such as the Numbers Bars Calculated Values study.
We have put together a Study Collection that has what you are looking for using the Numbers Bars Calculated Values and the Study Subgraph Above/Below Bar as Text. This will only work with the latest version of Sierra Chart, so be sure to upgrade first. You can find this collection here:
https://www.sierrachart.com/AdditionalFiles/BarRangeTextAboveBar.StdyCollct
In order to use this file, follow the instructions here:
How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection
Date Time Of Last Edit: 2018-06-14 19:42:31
[2018-06-15 06:26:20]
User164231 - Posts: 278
Thanks!
