Date/Time: Mon, 20 Jan 2025 11:21:29 +0000
Bar marking instead of numbering
View Count: 699
[2018-06-13 18:59:08] |
User459170 - Posts: 262 |
Hi instead of numbering bars, is there a way to mark every nth bar? In bar numbering we are able to number every nth bar, is there a way to change it into a marker every nth bar? Thanks
Date Time Of Last Edit: 2018-06-13 18:59:26
[2018-06-13 19:23:17] |
You would have to modify that study to meet your requirements. Refer to this page for instructions: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-13 19:23:30
[2018-06-13 19:50:19] |
Sawtooth - Posts: 4157 |
Have a look at this thread: how to re-color every x bars? |
