Date/Time: Mon, 21 Sep 2026 02:20:57 +0000
[Programming Help] - Example study
View Count: 885
[2018-06-13 17:35:33]
User252419 - Posts: 236
Could you give me an example of the result of the difference of Bid_Stack/Pull_Value(Sum of 10 levels)-Ask_Stack/Pull_Value(Sum of 10 levels) stored over time plotted in a line/bar? I don't know how to store the result of this difference over time and plot it in a line/bar for each bar period.
Here is a similar study but I don't know how to do what I've just said. Should be pretty simple for you.
Thank you,
SCSFExport scsf_MarketDepthPullingStackingValuesExample(SCStudyInterfaceRef sc)
SCSubgraphRef BidPullingStackingSubgraph = sc.Subgraph[0];
SCSubgraphRef AskPullingStackingSubgraph = sc.Subgraph[1];
if (sc.SetDefaults)
// Set the configuration and defaults
sc.GraphName = "Market Depth Pulling/Stacking Values Example";
sc.GraphRegion = 1;
sc.AutoLoop = 0;
sc.FreeDLL = 0;
BidPullingStackingSubgraph.Name = "Bid";
BidPullingStackingSubgraph.DrawStyle = DRAWSTYLE_LINE;
AskPullingStackingSubgraph.Name = "Ask";
AskPullingStackingSubgraph.DrawStyle = DRAWSTYLE_LINE;
return;
//The following two functions will return 0 if there is no pulling and stacking value at the specified price
BidPullingStackingSubgraph[sc.ArraySize - 1] = (float)sc.GetBidMarketDepthStackPullValueAtPrice(sc.Bid);
AskPullingStackingSubgraph[sc.ArraySize - 1] = (float)sc.GetAskMarketDepthStackPullValueAtPrice(sc.Ask);
Date Time Of Last Edit: 2018-06-13 17:39:34
