Date/Time: Mon, 20 Jan 2025 11:18:32 +0000
VWAP Study Problem
View Count: 900
[2018-06-13 14:45:33] |
User103861 - Posts: 42 |
I have used the VWAP study for months without issue but for some reason when opening my charts today, instead of the VWAP line continuing to the right edge of the window, it suddenly stops at yesterdays candle and attaches itself to todays candle. I have 4 different charts with this study and all charts are doing this. I have made no chages to these studies and again have had no problems for months until today. Please see attached image for reference. Please advise how to fix this. Thx.
Private File |
[2018-06-13 18:36:17] |
Provide us that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-13 18:44:06] |
File uploaded
Private File |
[2018-06-13 20:04:48] |
What you see is correct. Refer Start Date-Time here: Volume Weighted Average Price (VWAP) with Standard Deviation Lines: Inputs Today is the date that the 1000 day calculation is resetting. We will add a new input to the study to ignore the TimePeriod Type and Length. And just use the Start Date-Time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-13 20:05:14
