Date/Time: Mon, 20 Jan 2025 11:25:28 +0000
split session volume profile
View Count: 1714
[2018-06-13 13:56:27]
User339776 - Posts: 22
hi. i have split my ES profile chart to RTH and Globex sessions. i would like to use different colours for these sessions for the letters and volumes. is this possible?
Thanks,
imageImage [2].png / V - Attached On 2018-06-13 13:56:18 UTC - Size: 112.61 KB - 500 views
[2018-06-13 19:06:53]
Yes it is but you need to update to the latest prerelease following the instructions here:
And then this is controlled with a new setting with this Input:
Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Colors (TPO Letter/Block Colors)
Date Time Of Last Edit: 2018-06-13 19:07:55
[2018-06-14 09:37:49]
Great! Thank you!
[2018-06-15 06:13:00]
also, is it possible to put the previous days Volume profile only on a a candle stick chart on the far right of the screen. and also make a composite volume profile of say the last week/month. i can only see how to do this for what is showing on the screen
[2018-06-15 18:30:49]
Refer to:
Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart
