Date/Time: Mon, 20 Jan 2025 11:15:54 +0000
[Locked] - PnL Display format in Trade DOM: Ticks - Ignore Quantity
View Count: 1337
[2018-06-13 10:50:29] |
ticinotrader - Posts: 398 |
I would like to display the PnL in my DOMs in 'Ticks - Ignore Quantity' format. I already selected this display mode in the Chart Settings -> Advanced settings but it affects the PnL display on the open position line only - at the top of the DOM, the PnL is still displayed in Ticks, multiplied by the traded contract size. Can you please let me know how can I set the DOM to display PnL in 'Ticks - Ignore Quantity' format? Thank you! |
[2018-06-13 19:18:06] |
Are you asking about the Daily Profit/Loss? The Daily Profit/Loss cannot use this setting.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-30 17:38:29
[2018-06-13 19:19:27] |
Yes, I was referring to that.
