Date/Time: Sun, 19 May 2024 20:00:19 +0000
symbols for Euronext Amsterdam
View Count: 972
[2018-06-12 13:29:39] |
User499112 - Posts: 2 |
Hi, what are the stock symbols for Euronext Amsterdam for stocks like ING, Philips of Unilever? Is there a list with symbols, I cannot find. Thanks in advance |
[2018-06-12 17:57:30] |
These symbols from this exchange are only supported when using Interactive Brokers. Refer to this page: Interactive Brokers Trading Service Otherwise, they are not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-12 17:59:17] |
But we are checking with our data provider to see if they do have Euronext Amsterdam. Maybe this is now available.
[2018-06-12 18:32:09] |
thanks
[2018-06-15 05:38:28] |
This is the answer we have from our data provider in regards to this: We do not at this time, but we are looking at on-boarding this exchange as delayed by the end of this summer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-08 19:53:54] |
stephane1 - Posts: 110 |
Hi, Now is avalaible ? and Euronext Paris ? regards SR |
[2020-01-14 18:43:29] |
What we can start to offer soon is: Real-time Cboe Europe equities (BXE and CXE). Let us know if that is what you would be looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
