Date/Time: Sun, 24 Nov 2024 07:44:27 +0000
new default spreadsheet for trading
View Count: 1585
[2013-10-14 01:42:59]
shane a mcdonald - Posts: 18
I think I have changed the default spreadsheet for automated trading.
How can I get the original default spreadsheet for trading ?
I hit save after making some changes to experiment.
shane
[2013-10-14 03:38:56]
The easiest thing to do would be to click at the top left of the Sheet within the Spreadsheet being used by the Spreadsheet study to select all of the cells and then press the Delete key on your keyboard.
Go back to the Chart that has the Spreadsheet System for Trading study and select Chart >> Recalculate.
[2013-10-14 11:04:12]
thank you for your help
I did what you said
I do not think it worked . I posted screenshot of what spreadsheet looks like. I have altered default spreadsheet I think.
shane
Date Time Of Last Edit: 2013-10-14 11:17:34
imagespread1.png / V - Attached On 2013-10-14 11:14:33 UTC - Size: 196.01 KB - 449 views
[2013-10-14 17:11:20]
Another thing you can do is close the Chartbook (File >> Close Chartbook). And then select File >> Open Spreadsheet. Delete the DefaultSpreadsheetStudy file.
After that reopen the Chartbook which contains the Spreadsheet study.
[2013-10-14 17:49:03]
hi
that worked ! perfect
thanks again for your help
shane
