Date/Time: Sun, 24 Nov 2024 07:45:54 +0000
study subgraph size
View Count: 2285
[2013-10-14 01:00:05] |
shane a mcdonald - Posts: 18 |
hi is there any way to resize the lower subgraph on a study like the MACD for instance ? I would like to make the size smaller in height. thanks shane |
[2013-10-14 03:31:08] |
Yes. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ChartWindowandRegions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
