Date/Time: Mon, 20 Jan 2025 11:20:24 +0000
buy/sell STOP order executes as market order on chart DOM
View Count: 862
[2018-06-11 14:47:24] |
DevTrader79 - Posts: 44 |
On the chart DOM if I place Either buy or sell STOP order (for buy, above the price and for sell, below the price) it triggers as a market order. Don't know what setting got messed up.
[2018-06-11 16:07:24] |
Xfanman1 - Posts: 320 |
Did you check your Chart DOM Settings to see if they are still set correctly? -- Scott |
Chart DOM Settings.PNG / V - Attached On 2018-06-11 16:07:14 UTC - Size: 79.52 KB - 345 views |
[2018-06-11 17:11:07] |
Check the actual configured order types for the Chart DOM. Refer to: Global Trade Settings Windows: Chart DOM Settings It sounds as though a Limit order is being used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-11 17:11:28
[2018-06-12 13:43:15] |
Thank you Scott for the screenshot. It helped a lot. After installing through wine on Arch linux the order DOM config got messed up. Now everything works perfectly. |
