Date/Time: Mon, 20 Jan 2025 11:13:22 +0000
Curious
View Count: 790
[2018-06-11 11:17:27] |
Alberto Gauer - Posts: 121 |
This is a bit annoying. The only chart in my chartbook that refuses to load and calculate when opening a chartbook (it hangs then I have to click to cancel, remove a study that is causing this (VWAP), and then choose "reload and recalculate" and only then it fully loads) is the NVOL-NYSE_NASDAQ_NYSE_MKT IF VWAP study is among the list of studies. If I remove VWAP before "save all" after closing Sierra, charts opens fine.
[2018-06-11 17:39:10] |
We are doing some work with the underlying processing of Volume Weighted Average Price that might help with this. However, one thing we recommend doing is to set the Base on Underlying Data Input to No: Volume Weighted Average Price (VWAP) with Standard Deviation Lines: Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-11 17:39:34
