Date/Time: Tue, 21 Jan 2025 00:53:58 +0000
Spreadsheet to ACSIL
View Count: 1048
[2018-06-11 10:43:07] |
User252419 - Posts: 235 |
Is there any documentation or method in order to translate a spreadsheet into an ACSIL code? Thank you Date Time Of Last Edit: 2018-06-11 10:48:20
[2018-06-11 17:39:59] |
No something like this would be much too complicated to do programmatically.
[2018-07-18 21:56:11] |
ForgivingComputers.com - Posts: 987 |
I started creating spreadsheet studies and used them as a basis for learning ACSIL. There are arrays for base data and studies and sc.Subgraph[n][sc.Index], where n is a number that represents your formula column. [sc.Index] represents the latest bar, and [sc.Index-1] represents the bar before that, etc. If you know c++ or have some programming experience, you should be able to pick up enough from the example code in the ACS_Source folder, and the very through online documentation. I suggest you use remote build instead of Visual Studio, if you want to minimize the number of new things you need to learn. If you want someone to do this for you, I can give you a quote. brad@forgivingcomputers.com |
