Date/Time: Mon, 20 Jan 2025 11:25:22 +0000
Charts in the wrong chartbook
View Count: 923
[2018-06-10 15:18:42]
User568537 - Posts: 21
Hi
I created a chartbook (A) with some charts (all of them about symbol "X");
then I created a second chartbook (B) (with some charts about a different symbol "Y") and in it I duplicated few charts coming from (A) and applied to such last charts symbol "Y";
finally I repeated the duplicating process copying few charts this time from chartbook (B) to the first one (A) (and applying to them symbol "X").
Now when I launch Sierra and open both chartbooks (A) and (B) I find that few charts of chartbook (A) show in chartbook (B) and the other way around; if I delete the unwanted charts they disappear from their original chartbook (and I have to re-create them again).
PROBABLY this happens with those charts which I copied from (A) to (B) and from (B) to (A), but I am not sure (I did a lot of creating, copying and deleting...)
Any solution?
Thanks.
[2018-06-10 22:11:48]
First, it is not possible at all technically for a chart in one Chartbook to be part of another Chartbook.
However, if you have this option enabled for a chart , it will always be visible no matter what Chartbook is currently visible:
Window, CB and CW Menus: Window Always Visible (Window)
Date Time Of Last Edit: 2018-06-10 22:12:30
[2018-06-11 21:52:21]
In fact I had forgotten to unflag the "always visible" command...
Thanks.
