Date/Time: Mon, 20 Jan 2025 08:31:36 +0000
dll build is failing
View Count: 657
[2018-06-08 09:20:56] |
User61576 - Posts: 445 |
when trying to build advanced custom studies dll I am getting an error "The system cannot find the path specified." How do i tell Sc that VS2017 is installed on my computer? |
[2018-06-08 10:08:14] |
Use the Remote Build instead. See step 19.9 here: Advanced Custom Study Interface and Language (ACSIL): Step-By-Step Instructions to Create an Advanced Custom Study Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-08 10:08:24
