Date/Time: Mon, 20 Jan 2025 08:34:17 +0000
RTY Globex Emini Russell
View Count: 937
[2018-06-07 21:07:20] |
User16952 - Posts: 6 |
Does your real time data service include the exchange or is that something I pick up from IB. Checking to see what I can cancel, I got CME Real time ($1.25) and Russell tick Indices real time (2.00) Thanks Kim Fields |
[2018-06-07 21:11:03] |
The supported exchanges are here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SupportedExchanges The Russell cash indices are no longer supported. You will need to get that data from Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
