Date/Time: Mon, 20 Jan 2025 11:26:24 +0000
Vertical Tool Issue
View Count: 674
[2018-06-07 15:04:26]
User536593 - Posts: 11
When I attempt to add a vertical line on a chart, i point to where i want it located and it
sets to the left of the location 2-3 bars. However, the is NOT true in all cases.
I am using Renko Bars
Any fixes. This is a recent problem
[2018-06-07 18:13:14]
This would have to be a data timestamp issue. Not with the drawing tool itself.
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download".
[2018-06-12 14:13:26]
tried that and did not fix issue. Using version 1762 now on Desktop and Laptop, same issue on both.
When using the vertical line, i can highlight 2 or 3 locations the the alignment is off
by 1 or 2 bars. Using Renko 5tick on NQ. Same for arrow.
[2018-06-12 17:31:16]
We are unable to reproduce this problem. Can you please include a screenshot with the Vertical line in the incorrect position and tell us the time zone of the chart.
Here are instructions:
Also, when you see this problem, is it showing the Vertical Line in the incorrect location before you left-click, or does it shift after you click to place the line?
Date Time Of Last Edit: 2018-06-12 17:31:35
