Date/Time: Mon, 20 Jan 2025 08:29:23 +0000
Retrieving Older Contracts?
View Count: 994
[2018-06-07 13:25:44] |
User90927 - Posts: 38 |
Is it possible to retrieve old contracts for research. For Example I want to bring up the ES mini contract for ESM18...at the moment the Sept contract ESU18 is running? |
[2018-06-07 13:57:09] |
Xfanman1 - Posts: 320 |
Just type the old contract name in Chart Settings and turn off the Auto Rollover checkbox if it's on. By the way, volume is still higher for the June contract than the September contract for now. Scott Date Time Of Last Edit: 2018-06-07 13:58:43
[2018-06-07 14:12:10] |
User181655 - Posts: 61 |
Thanks Scott Regards Satnam |
[2018-06-08 19:36:56] |
This is explained here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Using Expired Futures Contracts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
