Date/Time: Wed, 27 Nov 2024 00:22:22 +0000
volume by price
View Count: 1314
[2013-03-20 22:24:10]
amk44 - Posts: 10
can you please see if you can be able to make the volume by price merge like the tpo profile does merges it would be very useful
alan kennedy
amk44
[2013-03-20 22:41:06]
Perhaps next year. This is hugely advanced. It is not something that we really we foresee adding. We have a feature called Tools >> Draw Volume Profile which lets you apply volume profile to a specific timeframe on the chart. Hopefully that will meet your needs. For more information, please see:
http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#DrawVolumeProfile
What you can also do is use the TPO Profile Chart study. Add a Volume by Price study to the chart also. When you split and merge TPO Profiles, this will also affect the Volume Profiles.
Date Time Of Last Edit: 2013-03-20 22:43:30
[2014-04-21 03:49:24]
Profile Trader - Posts: 174
I would like to put a +1 Vote to have this revised. I have been using the TPO profile with the VbP to facilitate this currently but this leaves major issues with formatting and what you can view within a screen.... With the increased interest in MP both time and volume I think it would be a well received option.
Thanks for your time and consideration.
Doug
[2014-04-21 04:37:42]
It is not something that we really we foresee adding. We have a feature called Tools >> Draw Volume Profile which lets you draw volume profile for a specific period of time on the chart and adjust that profile at any time later. Hopefully that will meet your needs. For more information, see:
Date Time Of Last Edit: 2014-04-21 04:38:25
[2014-07-02 16:01:10]
bronson - Posts: 14
Can you add in the setting of VBP and the setting of the DOM ( in customize tradeDOM columns) , the ability to add the VWAP and their standarts deviations ,see the screen attached please.
imagemesse sierra.JPG / V - Attached On 2014-07-02 15:55:07 UTC - Size: 173.27 KB - 372 views
[2014-07-02 16:05:15]
For this you must use Volume Weighted Average Price study.
There are no plans to be adding what you are requesting.
Date Time Of Last Edit: 2014-07-02 16:05:24
