Date/Time: Mon, 20 Jan 2025 08:34:35 +0000
updating sierrachart
View Count: 767
[2018-06-07 01:46:27] |
dtl-saw - Posts: 79 |
i used to be able to install previous versions of the SC using the /help/download prerelease and then a dialog box would pause to allow me to enter a prerelease number etc. what happens now is that it downloads and installs the prerelease version the same way that it does when intalling current version - that is there is no pause for gui inputs but instead it just downloads the current prerelease and installs it. did you design this new behavior or is there a preference or file i need to change somewhere in order to be able to input the release version number i want installed if it's not the current prerelease version? thanks |
[2018-06-07 02:33:43] |
The installation process does start automatically but we can see how this is a problem for rolling back to a prior version so we will prevent the automatic start. The other thing is you can just press the Cancel button and just interrupt the installation process and then you can interact with the controls. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-07 02:35:09
[2018-06-07 03:08:12] |
thanks for doing that, i think it was much more intuitive the way you had it before.
