Date/Time: Mon, 20 Jan 2025 08:22:09 +0000
new version download
View Count: 1223
[2018-06-06 20:58:17] |
User644706 - Posts: 5 |
Greetings...I downloaded the latest version of the trading platform today (v1759) and it completely changed the Rahul Mohindar Oscillator setting that I previously used ...there are now 6 inputs when there were only 4 prior to the upgrade and I can't get it back to the settings I had before...is this something you are aware of? or a glitch in the download?...it's the only study I trade with and I would prefer to have it back to the way I'm used to using it if that's possible. Thanks. JZ |
[2018-06-06 21:06:32] |
User296719 - Posts: 21 |
Did you try rolling back to the previous version of Sierra charts?
[2018-06-06 21:13:36] |
I did...it says I'm using the rolled back vs of 1758 (32-bit) but the RMO is still changed...I forgot to mention the drop down arrow on the settings of the RMO also stopped working...it just flashes and disappears...thx
[2018-06-06 21:19:51] |
That study was recently updated to conform to the proper formula for it. What particular drop-down list are you referring to.? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-06 21:45:26] |
The dropdown in the study settings for changing the parameters of the different components that make up the RMO i.e hidden, line, bar etc......any way to get the old formula and make a custom study with it...it works completely different than before.
[2018-06-06 21:48:36] |
is there any way I can go back a few versions and get the old RMO parameters?...
[2018-06-07 00:22:22] |
Yes you can go back to an older version and the procedure is explained here: http://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#Rollback The listbox you are referring to is on the study Subgraphs tab: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#SubgraphsTab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-07 09:45:41] |
Thanks, I appreciate the help...I rolled it back via the method in the link already but it left me with and older version but with the same new RMO study...last night I tried a System Restore point of 5/24/2018 and that did the trick...my problem is I won't ever be able to go to a newer version...is there any chance I could get the code for the older version of the RMO and build it again as a custom study?...that way I could name that one something else and likely avoid this if I'm ever forced to upgrade in the future...
[2018-06-07 20:46:17] |
To access the source code for that or any other study, refer to the documentation here: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-07 20:51:18
