Date/Time: Mon, 20 Jan 2025 11:09:21 +0000
Rithmic Log
View Count: 986
[2018-06-06 19:47:48]
gmorgan111 - Posts: 121
Here is the requested log
Reading Internal Order ID file. | 2018-06-06 14:42:49
Reading Trade Orders file. | 2018-06-06 14:42:49
Reading Trade Positions file. | 2018-06-06 14:42:49
Listening on UDP port 22903. | 2018-06-06 14:42:49
Software version: 1746 64-bit | 2018-06-06 14:42:49
Usage end date: 2018-06-20 | 2018-06-06 14:42:49
Enabled for: Advanced Features. | 2018-06-06 14:42:49
Enabled for: Advanced Features 2. | 2018-06-06 14:42:49
Enabled for: Sierra Chart Historical Data Service. | 2018-06-06 14:42:49
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-06-06 14:42:49
Current selected Data/Trading service: Rithmic Trading | 2018-06-06 14:42:49
Chart Update Interval: 500 | 2018-06-06 14:42:49
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-06-06 14:42:49
2018-06-06 14:42:49 Local computer time | 2018-06-06 14:42:49
2018-06-06 19:42:49 Local computer time in UTC | 2018-06-06 14:42:49
2018-06-06 14:42:49 Local computer time in SC Time Zone | 2018-06-06 14:42:49
2018-06-06 19:42:49 Server time in UTC | 2018-06-06 14:42:49
Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-06-06 14:42:49
Program path: C:\SierraChart\ | 2018-06-06 14:42:49
Data Files path: C:\SierraChart\Data\ | 2018-06-06 14:42:49
OS Version Number: 10.0 | 2018-06-06 14:42:49
Locale Setting: C | 2018-06-06 14:42:49
Checking for new symbol settings for service code rithmic.trading | 2018-06-06 14:42:49
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-06-06 14:42:49
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-06-06 14:42:49
Symbol settings are up-to-date for rithmic.trading | 2018-06-06 14:42:50
Received 5 login tokens. | 2018-06-06 14:42:50
HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-06-06 14:42:51
HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-06-06 14:42:51
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-06-06 14:42:55
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-06-06 14:42:55
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-06-06 14:42:55
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-06 14:42:55
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-06-06 14:42:55
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-06-06 14:42:55
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-06-06 14:42:55
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-06-06 14:42:55
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-06 14:42:55
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-06-06 14:42:55
HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-06-06 14:42:57
HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-06-06 14:42:57
HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-06-06 14:42:57
HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-06 14:42:57
HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-06-06 14:42:57
Rithmic Trading | Port for executable: 52171 | 2018-06-06 14:43:00
Listening socket (1388). Port 52171 | Closed. | 2018-06-06 14:43:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:43:00
Rithmic Trading | Bridge process is running. | 2018-06-06 14:43:02
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52171 | 2018-06-06 14:43:02
DTC Client socket (6) | Creating socket. | 2018-06-06 14:43:02
DTC Client socket (6) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:43:02
Rithmic Trading | Connected to server. | 2018-06-06 14:43:02
Rithmic Trading | Starting socket receive thread. | 2018-06-06 14:43:02
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-06-06 14:43:02
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-06-06 14:43:02
Rithmic Trading | Sending logon request message. | 2018-06-06 14:43:02
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-06-06 14:43:02
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-06-06 14:43:02
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-06-06 14:43:02
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2018-06-06 14:43:31
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2018-06-06 14:43:52
Rithmic Trading | Received logon response. | 2018-06-06 14:43:52
Rithmic Trading | Server Name: DTC Bridge. | 2018-06-06 14:43:52
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-06-06 14:43:52
Rithmic Trading | Logon error received from server | 2018-06-06 14:43:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:43:52
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:43:52
DTC Client socket (6) | Initiating close of socket by core. | 2018-06-06 14:43:52
Rithmic Trading | Disconnected. | 2018-06-06 14:43:52
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:43:52
DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2018-06-06 14:43:52
Rithmic Trading | Port for executable: 52207 | 2018-06-06 14:43:54
Listening socket (1124). Port 52207 | Closed. | 2018-06-06 14:43:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:43:54
Rithmic Trading | Bridge process is not running! | 2018-06-06 14:43:56
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52207 | 2018-06-06 14:43:56
DTC Client socket (8) | Creating socket. | 2018-06-06 14:43:56
DTC Client socket (8) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:43:56
DTC Client socket (8) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-06-06 14:43:57 *
DTC Client socket (8) | Initiating close of socket by core. | 2018-06-06 14:43:57
DTC Client socket (8) | Closed. | 2018-06-06 14:43:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:43:57
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:43:57
Rithmic Trading | Disconnected. | 2018-06-06 14:43:57
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:43:57
Rithmic Trading | Port for executable: 52210 | 2018-06-06 14:43:59
Listening socket (1124). Port 52210 | Closed. | 2018-06-06 14:43:59
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:43:59
Rithmic Trading | Bridge process is not running! | 2018-06-06 14:44:01
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52210 | 2018-06-06 14:44:01
DTC Client socket (9) | Creating socket. | 2018-06-06 14:44:01
DTC Client socket (9) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:44:01
DTC Client socket (9) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-06-06 14:44:02 *
DTC Client socket (9) | Initiating close of socket by core. | 2018-06-06 14:44:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:44:02
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:44:02
DTC Client socket (9) | Closed. | 2018-06-06 14:44:02
Rithmic Trading | Disconnected. | 2018-06-06 14:44:02
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:44:02
Rithmic Trading | Port for executable: 52212 | 2018-06-06 14:44:04
Listening socket (1124). Port 52212 | Closed. | 2018-06-06 14:44:04
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:44:04
Rithmic Trading | Bridge process is not running! | 2018-06-06 14:44:06
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52212 | 2018-06-06 14:44:06
DTC Client socket (10) | Creating socket. | 2018-06-06 14:44:06
DTC Client socket (10) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:44:06
DTC Client socket (10) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-06-06 14:44:07 *
DTC Client socket (10) | Initiating close of socket by core. | 2018-06-06 14:44:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:44:07
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:44:07
DTC Client socket (10) | Closed. | 2018-06-06 14:44:07
Rithmic Trading | Disconnected. | 2018-06-06 14:44:07
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:44:07
Rithmic Trading | Port for executable: 52216 | 2018-06-06 14:44:09
Listening socket (1124). Port 52216 | Closed. | 2018-06-06 14:44:09
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:44:09
Rithmic Trading | Bridge process is not running! | 2018-06-06 14:44:11
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52216 | 2018-06-06 14:44:11
DTC Client socket (11) | Creating socket. | 2018-06-06 14:44:11
DTC Client socket (11) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:44:11
DTC Client socket (11) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-06-06 14:44:12 *
DTC Client socket (11) | Initiating close of socket by core. | 2018-06-06 14:44:12
DTC Client socket (11) | Closed. | 2018-06-06 14:44:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:44:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:44:12
Rithmic Trading | Disconnected. | 2018-06-06 14:44:12
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:44:12
Rithmic Trading | Port for executable: 52221 | 2018-06-06 14:44:14
Listening socket (1260). Port 52221 | Closed. | 2018-06-06 14:44:14
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:44:14
DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-06-06 14:44:15 *
DTC Client socket (6) | Socket gracefully closed by remote side. | 2018-06-06 14:44:15
DTC Client socket (6) | Closed. | 2018-06-06 14:44:15
Rithmic Trading | Bridge process is not running! | 2018-06-06 14:44:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52221 | 2018-06-06 14:44:16
DTC Client socket (12) | Creating socket. | 2018-06-06 14:44:16
DTC Client socket (12) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:44:16
DTC Client socket (12) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-06-06 14:44:17 *
DTC Client socket (12) | Initiating close of socket by core. | 2018-06-06 14:44:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:44:17
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:44:17
DTC Client socket (12) | Closed. | 2018-06-06 14:44:17
Rithmic Trading | Disconnected. | 2018-06-06 14:44:17
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:44:17
Rithmic Trading | Port for executable: 52223 | 2018-06-06 14:44:19
Listening socket (1260). Port 52223 | Closed. | 2018-06-06 14:44:19
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:44:19
Rithmic Trading | Bridge process is running. | 2018-06-06 14:44:21
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52223 | 2018-06-06 14:44:21
DTC Client socket (13) | Creating socket. | 2018-06-06 14:44:21
DTC Client socket (13) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:44:21
Rithmic Trading | Connected to server. | 2018-06-06 14:44:21
Rithmic Trading | Starting socket receive thread. | 2018-06-06 14:44:21
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-06-06 14:44:21
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-06-06 14:44:21
Rithmic Trading | Sending logon request message. | 2018-06-06 14:44:21
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-06-06 14:44:21
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-06-06 14:44:21
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-06-06 14:44:21
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2018-06-06 14:44:51
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2018-06-06 14:45:12
Rithmic Trading | Received logon response. | 2018-06-06 14:45:12
Rithmic Trading | Server Name: DTC Bridge. | 2018-06-06 14:45:12
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-06-06 14:45:12
Rithmic Trading | Logon error received from server | 2018-06-06 14:45:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:45:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:45:12
DTC Client socket (13) | Initiating close of socket by core. | 2018-06-06 14:45:12
Rithmic Trading | Disconnected. | 2018-06-06 14:45:12
DTC Client socket (13) | Shutdown started. Waiting for graceful close. | 2018-06-06 14:45:12
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:45:12
Rithmic Trading | Port for executable: 52241 | 2018-06-06 14:45:14
Listening socket (1260). Port 52241 | Closed. | 2018-06-06 14:45:14
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:45:14
Rithmic Trading | Bridge process is not running! | 2018-06-06 14:45:16
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52241 | 2018-06-06 14:45:16
DTC Client socket (15) | Creating socket. | 2018-06-06 14:45:16
DTC Client socket (15) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:45:16
DTC Client socket (15) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-06-06 14:45:17 *
DTC Client socket (15) | Initiating close of socket by core. | 2018-06-06 14:45:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:45:17
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:45:17
DTC Client socket (15) | Closed. | 2018-06-06 14:45:17
Rithmic Trading | Disconnected. | 2018-06-06 14:45:17
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:45:17
Rithmic Trading | Port for executable: 52243 | 2018-06-06 14:45:19
Listening socket (1260). Port 52243 | Closed. | 2018-06-06 14:45:19
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:45:19
Rithmic Trading | Bridge process is not running! | 2018-06-06 14:45:21
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52243 | 2018-06-06 14:45:21
DTC Client socket (16) | Creating socket. | 2018-06-06 14:45:21
DTC Client socket (16) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:45:21
DTC Client socket (16) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-06-06 14:45:22 *
DTC Client socket (16) | Initiating close of socket by core. | 2018-06-06 14:45:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:45:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:45:22
DTC Client socket (16) | Closed. | 2018-06-06 14:45:22
Rithmic Trading | Disconnected. | 2018-06-06 14:45:22
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:45:22
Rithmic Trading | Port for executable: 52245 | 2018-06-06 14:45:24
Listening socket (1664). Port 52245 | Closed. | 2018-06-06 14:45:24
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:45:24
Rithmic Trading | Bridge process is not running! | 2018-06-06 14:45:26
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52245 | 2018-06-06 14:45:26
DTC Client socket (17) | Creating socket. | 2018-06-06 14:45:26
DTC Client socket (17) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:45:26
DTC Client socket (17) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-06-06 14:45:27 *
DTC Client socket (17) | Initiating close of socket by core. | 2018-06-06 14:45:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:45:27
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:45:27
DTC Client socket (17) | Closed. | 2018-06-06 14:45:27
Rithmic Trading | Disconnected. | 2018-06-06 14:45:27
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:45:27
Rithmic Trading | Port for executable: 52248 | 2018-06-06 14:45:29
Listening socket (1424). Port 52248 | Closed. | 2018-06-06 14:45:29
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:45:29
Rithmic Trading | Bridge process is not running! | 2018-06-06 14:45:31
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52248 | 2018-06-06 14:45:31
DTC Client socket (18) | Creating socket. | 2018-06-06 14:45:31
DTC Client socket (18) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:45:31
DTC Client socket (18) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-06-06 14:45:32 *
DTC Client socket (18) | Initiating close of socket by core. | 2018-06-06 14:45:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:45:32
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:45:32
DTC Client socket (18) | Closed. | 2018-06-06 14:45:32
Rithmic Trading | Disconnected. | 2018-06-06 14:45:32
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:45:32
Rithmic Trading | Port for executable: 52250 | 2018-06-06 14:45:34
Listening socket (1424). Port 52250 | Closed. | 2018-06-06 14:45:34
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:45:34
DTC Client socket (13) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-06-06 14:45:34 *
DTC Client socket (13) | Socket gracefully closed by remote side. | 2018-06-06 14:45:34
DTC Client socket (13) | Closed. | 2018-06-06 14:45:34
Rithmic Trading | Bridge process is not running! | 2018-06-06 14:45:36
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52250 | 2018-06-06 14:45:36
DTC Client socket (19) | Creating socket. | 2018-06-06 14:45:36
DTC Client socket (19) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:45:36
DTC Client socket (19) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-06-06 14:45:37 *
DTC Client socket (19) | Initiating close of socket by core. | 2018-06-06 14:45:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:45:37
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:45:37
DTC Client socket (19) | Closed. | 2018-06-06 14:45:37
Rithmic Trading | Disconnected. | 2018-06-06 14:45:37
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:45:37
Rithmic Trading | Port for executable: 52252 | 2018-06-06 14:45:39
Listening socket (1520). Port 52252 | Closed. | 2018-06-06 14:45:39
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:45:39
Rithmic Trading | Bridge process is running. | 2018-06-06 14:45:41
Rithmic Trading | Connecting to the server 127.0.0.1. Port 52252 | 2018-06-06 14:45:41
DTC Client socket (20) | Creating socket. | 2018-06-06 14:45:41
DTC Client socket (20) | Connecting to IP: 127.0.0.1. | 2018-06-06 14:45:41
Rithmic Trading | Connected to server. | 2018-06-06 14:45:41
Rithmic Trading | Starting socket receive thread. | 2018-06-06 14:45:41
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-06-06 14:45:41
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-06-06 14:45:41
Rithmic Trading | Sending logon request message. | 2018-06-06 14:45:41
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-06-06 14:45:41
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-06-06 14:45:41
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-06-06 14:45:41
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2018-06-06 14:46:10
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2018-06-06 14:46:31
Rithmic Trading | Received logon response. | 2018-06-06 14:46:31
Rithmic Trading | Server Name: DTC Bridge. | 2018-06-06 14:46:31
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-06-06 14:46:31
Rithmic Trading | Logon error received from server | 2018-06-06 14:46:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 14:46:31
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:46:31
DTC Client socket (20) | Initiating close of socket by core. | 2018-06-06 14:46:31
Rithmic Trading | Disconnected. | 2018-06-06 14:46:31
DTC Client socket (20) | Shutdown started. Waiting for graceful close. | 2018-06-06 14:46:31
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 14:46:31
Rithmic Trading | Port for executable: 52273 | 2018-06-06 14:46:33
Listening socket (1520). Port 52273 | Closed. | 2018-06-06 14:46:33
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 14:46:33
thanks
[2018-06-06 20:01:55]
Refer to this thread about this:
Rithmic Data Connection Failure
It explains everything.
[2018-06-09 11:24:17]
For an understanding about this issue, refer to this post here:
Rithmic Data Connection Failure | Post: 149895
