Date/Time: Mon, 20 Jan 2025 08:20:41 +0000
VS 2017 community and SC / ACSIL questions
View Count: 1539
[2018-06-06 18:54:02]
User61576 - Posts: 445
Hi there,
1. when trying to build advanced custom studies dll I am getting an error "The system cannot find the path specified."
How do i tell Sc that VS2017 is installed on my computer?
2. Can you pls update this support page?
https://www.sierrachart.com/index.php?page=doc/UsingVisualCPlusPlus.php
I am trying to setup VS 2017 community version but this page looks a bit old vs. options in VS2017
3. If I want to create a kind of heartbeat / latency counter for studying purposes, where would you suggest me to start with?sc.GetTimeAndSales(TimeSalesArray)?
btw your inhouse search engine is down and not working for some time...
[2018-06-06 19:12:49]
We are going to remove that page and we are not going to spend any time documenting Microsoft's trash and garbage products. Microsoft is in a state of deterioration at this point in time.
The website search does work properly. Are you referring to the search at the top right of the webpages.?
Date Time Of Last Edit: 2018-06-06 19:13:54
[2018-06-06 19:19:38]
Yes
also how should I handle question 1 and 3 above?
[2018-06-06 20:10:00]
Cavalry3162 - Posts: 523
@SC what IDE do you propose as an alternative?
thanks,
Andreas
[2018-06-07 21:02:11]
User132748 - Posts: 159
+1 What IDE is recomended?
[2018-06-07 22:59:00]
We need to do some research on this.
If the user is just building DLLs there certainly are going to be one or two reasonable alternatives out there.
But for now if anyone has trouble with Visual Studio or needs technical help just use the custom studies Remote Build within Sierra Chart instead.
For us we still have to rely on Visual C++. There really is no other alternative. At least not at this point in time but we do expect that would change in the coming years even if we have to build our own development environment. While Microsoft does have a lot of problems, the product is still capable and does what we need.
[2018-06-08 09:28:56]
The search at the top right of all of the webpages works just fine. That is very reliable. It would be hard to believe there is a problem considering the simplicity of the website implementation. Does anyone else see a problem with this?
1. We cannot help with this. Other than try using Analysis >> Build Custom Studies DLL >> MS Visual C++ >> Build Custom Studies DLL. First install the compiler though with the button just to the right.
Not totally sure what you are looking for, but you certainly can use that function if it meets your requirements.
Date Time Of Last Edit: 2018-06-08 09:29:28
[2018-06-08 09:51:50]
As soon as we said there is no problem with the search, we do now notice this at the moment. But we will solve that. This is a rare issue. The search is 99.9 % up.
