Date/Time: Mon, 20 Jan 2025 11:12:09 +0000
not able to log in
View Count: 804
[2018-06-06 18:34:50]
User298588 - Posts: 19
hi
i wasnt able to log in for the last two hour, please check
thanks
[2018-06-06 18:38:38]
Rithmic Trading | Port for executable: 51572 | 2018-06-06 18:37:49
Listening socket (860). Port 51572 | Closed. | 2018-06-06 18:37:49
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 18:37:49
Rithmic Trading | Bridge process is not running! | 2018-06-06 18:37:51
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51572 | 2018-06-06 18:37:51
DTC Client socket (46) | Creating socket. | 2018-06-06 18:37:51
DTC Client socket (46) | Connecting to IP: 127.0.0.1. | 2018-06-06 18:37:51
DTC Client socket (46) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2018-06-06 18:37:52 *
DTC Client socket (46) | Initiating close of socket by core. | 2018-06-06 18:37:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 18:37:52
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 18:37:52
DTC Client socket (46) | Closed. | 2018-06-06 18:37:52
Rithmic Trading | Disconnected. | 2018-06-06 18:37:52
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 18:37:52
Rithmic Trading | Port for executable: 51575 | 2018-06-06 18:37:54
Listening socket (744). Port 51575 | Closed. | 2018-06-06 18:37:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-06-06 18:37:54
Rithmic Trading | Bridge process is not running! | 2018-06-06 18:37:57
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51575 | 2018-06-06 18:37:57
DTC Client socket (47) | Creating socket. | 2018-06-06 18:37:57
DTC Client socket (47) | Connecting to IP: 127.0.0.1. | 2018-06-06 18:37:57
DTC Client socket (47) | Connect event error. Windows error code 10061: 由于目标计算机积极拒绝,无法连接。 | 2018-06-06 18:37:58 *
DTC Client socket (47) | Initiating close of socket by core. | 2018-06-06 18:37:58
DTC Client socket (47) | Closed. | 2018-06-06 18:37:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-06-06 18:37:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 18:37:58
Rithmic Trading | Disconnected. | 2018-06-06 18:37:58
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-06-06 18:37:58
[2018-06-06 19:25:29]
Refer to this page:
Rithmic Data Connection Failure
[2018-06-09 11:24:32]
For an understanding about this issue, refer to this post here:
Rithmic Data Connection Failure | Post: 149895
