Date/Time: Thu, 16 Jan 2025 00:48:14 +0000
TPO
View Count: 1743
[2018-06-06 13:02:53]
Robert Wojczak - Posts: 145
When using the 24 hour market for CL I would like the globex session letters to be all one color. Then when the pit session opens I want it to start with A period in a different color. How do I do that?
[2018-06-06 20:32:37]
You can set the colors for the individual subperiods within the TPO profile. Refer to these Input settings:
Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Colors
Time Price Opportunity (TPO) Profile Charts: Letter/Block Color 1-18
Date Time Of Last Edit: 2018-06-06 20:33:34
[2018-06-06 21:40:03]
Alberto Gauer - Posts: 121
I think there is no way to do that, only if there was 46 Letter\Block colors.
What can be done is having one profile for the day and other for the night, then it´s possible to have one of each color, like in this screenshot I took here.
imagesierra tpo day night different colors.png / V - Attached On 2018-06-06 21:39:57 UTC - Size: 140.8 KB - 371 views
[2018-06-06 23:31:16]
We will look into adding 48 colors. It is also possible to display the day and evening sessions separately:
Time Price Opportunity (TPO) Profile Charts: New Period at Day Session Start When Using Evening Session (1 Day Period Only)
But we see that we need to add a separate color setting for the evening session and we are going to do that today.
[2018-06-07 00:15:45]
We now have separate coloring for the evening session supported. This will be out in the next release:
http://www.sierrachart.com/image.php?Image=1528330463245.png
[2018-06-09 16:36:08]
Hello Engineering guys!
Where is the option to do that in the study settings? How´s it called?
Date Time Of Last Edit: 2018-06-09 16:36:30
[2018-06-09 21:50:56]
It is a new item in this Input:
Make sure you are running Sierra Chart version 1761.
[2018-06-10 12:38:23]
You now have to update the "highlight value area and POC" to be independent options, cause it´s causing confusion when you have a 24hs profile and this option chosen. I have attached some images. Now I can´t see my TPO POC highlighted without having the value are highlighted too, but for splitted color session gets confusing the white in the middle of the profile.
Date Time Of Last Edit: 2018-06-11 11:00:39
imageSIERRA TPO UPDATE.png / V - Attached On 2018-06-10 12:38:05 UTC - Size: 61.81 KB - 402 views
imageSIERRA TPO UPDATE2.png / V - Attached On 2018-06-10 12:38:16 UTC - Size: 45.32 KB - 331 views
[2018-06-13 14:04:28]
John - SC Support - Posts: 37270
We are looking into this.
[2018-06-13 19:00:00]
We will separate those options.
[2018-06-13 19:02:33]
As soon as we have the documentation ready for separate colors for the day and evening session we will post it here.
[2018-06-13 19:06:13]
The documentation for the TPO Letter/Block Colors has been updated to include the new selection of Separate Colors for Day and Evening Sessions. You can find the documentation here:
[2018-06-14 19:00:54]
We have updated the TPO study to have separate Inputs for Highlight TPO Value Area and Highlight TPO POC. The documentation can be found here:
Time Price Opportunity (TPO) Profile Charts: Highlight TPO Value Area
This will be in the next Pre-Release - 1766. There is no specific timeline for the update, but it is usually only a day or two. You can find the current Pre-Release number on the main Sierra Chart homepage in the upper right corner.
Once available, you can update to the latest release using these instructions:
Date Time Of Last Edit: 2018-06-14 19:14:49
