Date/Time: Mon, 20 Jan 2025 08:33:22 +0000
GERMAN DAX REAL TIME
View Count: 1047
[2018-06-06 12:31:27] |
User207223 - Posts: 15 |
Hi What is the difference between Eurex with Market Depth and EUREX Professional Feed, including Market Depth? thk s |
[2018-06-06 17:50:02] |
If the Exchange decides that you are a "Professional", you will only be able to subscribe to the "Professional" Exchange Option which is more expensive. There is no difference in data between these two exchange options.
