Date/Time: Fri, 25 Sep 2026 10:39:41 +0000
[Programming Help] - Building custom studies for 64-bit version
View Count: 1478
| [2018-06-06 05:38:53] |
| jj554 - Posts: 33 |
Hi, I am able to build custom studies for the 64-bit version using the built in tool, however I can't get it to work by building inside Visual Studio and outputting the DLL to the SierraChart\Data folder with the modified name $(ProjectName)_64. What am I doing wrong? Thanks |
| [2018-06-07 23:15:28] |
| WarriorTrader - Posts: 259 |
Hello, Have you tried compiling using Analysis -> Build Custom Study DLL and compile with the "MS Visual C++" ?? It compiles with your installed copy of Visual Studio. I used to use Visual Studio, but now I use the SC tool exclusively. It allows you to switch between may dll's quickly. The Notepad++ editor is also superior to VS in many ways although there is the rare occasion I do have to switch to VS for the IntelliSense. Good Trading, WT |
