Date/Time: Wed, 09 Sep 2026 04:08:10 +0000
[User Discussion] - Reset Pulling and Stacking
View Count: 3598
| [2018-06-05 17:19:52] |
| User104854 - Posts: 460 |
Can there be a way to reset the starting point of the pulling and stacking values? Depending on when the connection starts the values are significantly different when I get to a particular point in time. I don't typically disconnect from the data feed so my pulling and stacking values could be a running total from quite awhile ago. I would like to reset these values at a particular point in time just like the 'Clear Recent Bid and Ask Volume' feature. For the same reason traders don't need a running total of the recent bid and ask volume from awhile ago they don't need a running total of the pulling and stacking info and a reset feature would be helpful. Of course if there's a way to do it now besides disconnecting from the data feed please let me know. Thank you. |
| [2018-06-08 19:23:02] |
Did this go through???
| [2018-06-10 20:05:02] |
Hi. I sent this post 5 days ago and still have not had a response. Can someone get back to me please?
| [2019-04-17 02:36:48] |
| Acro - Posts: 459 |
Thanks for giving us a control bar button to clear/reset pulling and stacking. I can't find a keyboard shortcut to do the same thing. Would it be possible for a clear pulling stacking data keyboard shortcut be added to "Trade" shorcuts in the customize keyboard shortcuts menu ? Thanks for considering this |
| [2019-04-17 04:09:46] |
| User839162 - Posts: 87 |
@Acro - You can do this by going into Global Settings>Customize Keyboard Shortcuts>Trading Keyboard Shortcuts>Clear Pulling and Stacking Data> --- Then assign a key you'd like to use ---
| [2019-04-17 07:24:01] |
| Acro - Posts: 459 |
Cheers. I must have missed it
| [2019-09-10 01:24:34] |
| Acro - Posts: 459 |
Is there any way to have pulling stacking cleared/reset on a timed interval set by the user ? That would be really useful especially to get rid of pulling stacking data further away from price that may no longer have relevance (eg when say there was for stacking 25 levels away from price 20 mins ago and there has been no pulling or stacking at that price level since) |
| [2021-04-13 22:38:23] |
| User352451 - Posts: 3 |
Bump. This would be incredible useful. Most people only care about stacking/pullling happening right in the last few minutes vs hours ago.
| [2021-05-10 04:51:18] |
| User727583 - Posts: 6 |
I would also really value this functionality (the option for a user-defined periodic reset of pull/stack data). Thanks, SF |
| [2021-07-13 18:33:14] |
| tdd2672 - Posts: 63 |
Agreed!
