Date/Time: Mon, 20 Jan 2025 08:28:05 +0000
Write real time data on each bar close...
View Count: 1060
[2018-06-05 13:15:48] |
User895355 - Posts: 55 |
I'm familiar with "WriteBarData" and "WriteBarAndStudyData". The problem I'm having is I use the "Murrey Math Lines(MML)" and the only values that get exported are on the current bar, which is the last set of values in the exported data since they are constantly being recalculated. Therefore, I assume that the only way to get each MML value is to write it out in real time. What's the best way to do this?
Date Time Of Last Edit: 2018-06-05 13:17:06
[2018-06-05 19:59:25] |
You really have to create your own custom study to accomplish specifically what you need. Refer to: Advanced Custom Study Interface and Language (ACSIL) We do not provide programming help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-05 20:56:03
