Date/Time: Mon, 20 Jan 2025 08:28:01 +0000
Draw tool over Market Depth Historical Graph study
View Count: 1232
[2018-06-05 12:17:44] |
User578397 - Posts: 2 |
How can I draw any study (like an horizontal line or ray) over the Market Depth Historical Graph study? When I use this study, it overlaps all my graphic draws. Thanks, |
[2018-06-05 17:01:24] |
Check the following setting along with the one after it to see if these are enabled. Deselect them if you want the drawings to be above (in front of) the studies. Chart Settings: Draw Non-Highlight Chart Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
