Date/Time: Sun, 24 Nov 2024 08:07:17 +0000
Study works BUT "Custom study needs to be recompiled for this version of Sierra Chart"
View Count: 1690
[2013-10-12 19:02:56] |
hairyMug - Posts: 31 |
My study works fine but every time I load or backtest I have multiple messages: "Custom study needs to be recompiled for this version of Sierra Chart." What I have tried: 1. recompile 2. delete all traces of custom dll in "data" directory as well as "debug"; (except for source) 3. remove and reinstall SerriaChart (except for config file) Eventhough my study works OK, I still get the message. How do I get Serria to recognize that the version is correct? Suggestions? Note: I am running v1025 as this is the last version that shows any trade signals. |
[2013-10-13 00:31:03] |
fixed... SCDLLName statement was missing... |
[2013-10-13 01:46:49] |
This is good, however you should not get that error with the SCDLLName line missing. During testing we did discover a problem where a study function could still be called into with that line missing and that was corrected. That should not be allowed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
