Date/Time: Mon, 20 Jan 2025 08:21:25 +0000
Proposal for new Keyboard Shortcut
View Count: 616
[2018-06-05 07:12:55] |
User525997 - Posts: 20 |
Hi. The platform currently has the keyboard shortcut "Clear Recent Bid/Ask Volume on ChartDOM". It would be great if you could add a NEW shortcut which clears the recent Bid/Ask volume on ALL Chart Doms simultaneously. There is a shortcut which "Re-center all Trade DOM Scales". So I guess it is technically possible to do it. Best. Thomas |
[2018-06-06 02:43:20] |
Okay we will see about this.
