Date/Time: Mon, 20 Jan 2025 08:21:28 +0000
CTS Giving Partial Fills on a Market Order
View Count: 641
[2018-06-05 03:02:27]
User513662 - Posts: 90
I put a market order in for 8 contracts and the trade was split (I'm assuming because I have two targets) and CTS came back with a partial fill so I was filled 4 contracts and 3 contracts. How is this possible for a market order entry? My stop was then updated to 7 contracts, and my targets to 4 contracts and 3 contracts (two targets). Then I move my stop to break even which triggered, which should have made me flat, however I still had one contract open with no stops and targets?
This is has been happening frequently for market order entries, which by definition should not give you a partial fill?
Is this something you can look at or is it CTS or Topstep Trader? This is in the Top Step Trader combine.
I want to use the Advanced Connection Model but I have been advised by SC that this will not work in the combine.
Private File
[2018-06-05 06:14:05]
We think we know what the problem is.
Disable both of these options and do not use them again with CTS:
Global Trade Settings Windows: Use Server Side OCO Orders (if supported) (Global Settings >> General Trade Settings >> General)
Global Trade Settings Windows: Use Server Side Bracket Orders (if supported) (Global Settings >> General Trade Settings >> General)
[2018-06-05 06:15:48]
Partial fills can happen with market orders.
Also refer to our response above.
Date Time Of Last Edit: 2018-06-05 06:15:59
