Date/Time: Sun, 24 Nov 2024 07:43:13 +0000
T3
View Count: 2327
[2013-10-12 10:55:12] |
batman_ - Posts: 190 |
SC Can you teach me how to set T3 indicator in spreadsheet system for trading. I need to set; (1) "buy signal" is set when T3 indicator started to change color from the last closed red bar. (2) "Sell signal" is set when T3 indicator started to change color from the last closed blue bar. Thank you. |
[2013-10-14 17:42:05] |
We can only refer you to the example explained here: https://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#AutomatedTrading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
