Date/Time: Mon, 20 Jan 2025 08:16:23 +0000
Futures symbol
View Count: 743
[2018-06-04 17:36:39] |
User446139 - Posts: 7 |
I can download the symbol ESH0-CME for year 2010. Wich is the symbol for ES for 2009 and how far back can I go? Thank you.
[2018-06-04 18:43:52] |
These are Rithmic symbols and ESH0-CME should map to the year 2020 at this point in time. To get historical data that far back in time you need to use another installed instance of Sierra Chart and use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-04 18:44:03
