Date/Time: Mon, 20 Jan 2025 08:23:21 +0000
keyboard shortcut for last drawing tool used?
View Count: 846
[2018-06-04 06:23:47] |
whats1thingnow - Posts: 407 |
hi, i remember i read somewhere this was an option but i cannot find it anymore... anyway, is there a keyboard shortcut to activate the last drawing tool used? e.g. i use 'rectangle' tool
i finish drawing the rectangle since i have "tools settings" > "after single tool use change to 'hand'" ... my tool now is 'hand' at this point i use the keyboard shortcut for 'last tool used' then 'rectangle' tool is active again thanks for the help |
[2018-06-07 18:38:30] |
this would be tremendously useful :) any chance this can be added to the queue of feature request? or does anyone if this can be done already? thanks!! :) |
[2018-06-08 09:25:18] |
No, this is not currently supported. Only what you mentioned: "After Single Tool Use Change To".
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-08 09:25:28
