Date/Time: Sun, 24 Nov 2024 07:25:59 +0000
SierraChart 64 bit to download
View Count: 1828
[2013-10-12 08:02:22] |
FerroTrader - Posts: 70 |
Hello, is there the possibility to download SierraChart 64 bit software ? if not, are you plannig to release it ? is there a pdf documentation of all sierra chart function and C++ coding ? Thank You a lot, Andrew |
[2013-10-13 20:29:06] |
64 bit is not supported and there are no current plans for this. There is not a practical need for this. If memory use needs to exceed 3 GB, then you are better off by installing additional copies of Sierra Chart: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html 64-bit is not any faster. We do not offer PDF documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
