Date/Time: Fri, 31 Jan 2025 00:15:07 +0000
Message log - Array is unallocated
View Count: 919
[2018-06-03 13:28:02]
User781817 - Posts: 7
Since I installed Sierra Chart on my new computer, this message log started to appear. I have no idea what it means.
Please, could you help me with this issue..?
Thank you in advance,
Gabriela
Date Time Of Last Edit: 2018-06-04 18:53:23
imageMessage_log.jpg / V - Attached On 2018-06-03 13:23:53 UTC - Size: 143.53 KB - 314 views
[2018-06-04 18:58:53]
Update Sierra Chart to the current version following the instructions here:
If you still have this same error, then we will need to get the Chartbook you are using. Follow these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2019-04-01 14:59:32]
sierrasimon - Posts: 51
Hi, I got this message. Still after updating. It comes up every time I change some adjustments of chart or studies.
imageMessage log.JPG / V - Attached On 2019-04-01 14:57:41 UTC - Size: 68.69 KB - 306 views
Private File
[2019-04-01 17:04:41]
We had a look at this and we will add the necessary checks to prevent the error but the problem is is that you have set the Graph Draw Type for the Ask/Bid Volume Difference bars study to Price Volume Bars. You cannot do that. That is not supported with that study.
