Date/Time: Mon, 20 Jan 2025 08:25:17 +0000
VbP - Graph Period not changing
View Count: 727
[2018-06-03 10:39:41] |
User523480 - Posts: 18 |
Hello, After applying the VbP Study, every time I try to change the "volume graph period type" to anything else like " multiple profiles based on fixed time" and apply the new settings, the field changes back to "one period at end of fixed time length". In terms of output, it stays the same. How can I fix this ? |
[2018-06-03 21:36:26] |
One reason this can happen is when using this study with a trading DOM window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-03 21:37:17
