Date/Time: Mon, 20 Jan 2025 08:35:17 +0000
Price display format - US bonds
View Count: 1034
[2018-06-02 09:45:39] |
User495158 - Posts: 108 |
Hello! Is it possible to match price display format for US bonds in charts and DOM. Ie, to have price displayed like 119'25.00 instead of 119'25 and 119'25.50 instead of 119'25.5. I am already using "display fractions in short format" in General Settings. Please, see the attached screenshot to see what I mean. Thanks. |
Price display.jpg / V - Attached On 2018-06-02 09:44:22 UTC - Size: 323.84 KB - 313 views |
[2018-06-02 22:33:59] |
No, this is not supported.
[2018-06-03 06:27:17] |
Sorry, but that doesn't make sense to me. It seems like the same thing is displayed in two different ways for no apparent reason. Don't you think they should match?
[2018-06-04 00:57:06] |
We are not going to change this and cause complaints and for the time being we are not going to put an option in. The way it is displayed on the charts was the way it is originally displayed on the trading ladder interface but then a fixed width was used on the trading ladder interface to maintain a constant width which was necessary there. We cannot be pushed around by these suggestions and generate additional complaints. That is out of the question. So this is not going to change for now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-04 01:51:52
