Date/Time: Mon, 20 Jan 2025 08:26:55 +0000
Narrow range bars
View Count: 1568
[2018-06-02 07:16:14] |
User358040 - Posts: 21 |
Is there a possibility in sierra chart to track narrow range bars in a normal candle stick price chart? for exmaple: - inside bar - nr 4 bar - nr 7 bar or in general to start counting when we have the actual bar narrower then the prior bar and then count up till again I have a larger range bar Kind regards |
[2018-06-03 23:46:17] |
Would be best that we create a study that determines this. But we need more specific details as to how this is determined. An inside bar is understandable but not sure about narrow range 4 and 7. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-04 03:20:29] |
Acro - Posts: 441 |
I believe the user is talking about Toby Crabel's metrics in which case an nr4 bar has the narrowest range of the last four bars.
[2018-06-04 04:44:29] |
Okay, we can implement this.
[2018-06-04 15:45:23] |
o.k. thanks. One other question: how can I put below the spy chart for example the vxx symbol as a study? for exmaple just a line below the spy candle stick chart?
[2018-06-04 19:28:16] |
Use this study: Add Additional Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-04 19:50:28] |
User924725 - Posts: 26 |
isnt this already supported ? for NR days see image NR it is already a study and there is a study also for inside and outside bars coloring |
[2018-06-04 20:03:27] |
Yes that is true. We did not look. Use the Narrow Range Bar study: Narrow Range Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
