Date/Time: Mon, 20 Jan 2025 08:19:20 +0000
How to display the the Title Bar Name at the bottom the screen?
View Count: 1069
[2018-06-01 16:19:26] |
Dan the Man - Posts: 90 |
Hi, Please see attached screenshot. What setting is used to set to display the the "Title Bar Name" at the bottom the screen? Regards, Daniel |
Title Bar Name.jpg / V - Attached On 2018-06-01 16:17:15 UTC - Size: 258.07 KB - 360 views |
[2018-06-01 16:58:56] |
Refer to: Chart Settings: Use Title Bar Name as Tab Label (Chart >> Chart Settings >> Display >> Chart Display Items menu) And you can change the tab coloring in the Graphics Settings: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-01 17:34:50] |
Hi, This was already selected (see attached screenshot). The problem still remains that the Chart Title are not displayed at the bottom of the chart book. Regards, Daniel |
Title Bar Name - 1.jpg / V - Attached On 2018-06-01 17:34:41 UTC - Size: 608.38 KB - 399 views |
[2018-06-01 18:37:13] |
This must be a color settings issue. Check the two Chart Tab colors in the Graphics Settings: Graphics Settings But first update to the current version following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-01 18:37:44
