Date/Time: Mon, 20 Jan 2025 08:32:50 +0000
Number of Trades or Volume?
View Count: 1600
[2018-06-01 16:02:18] |
User691365 - Posts: 7 |
In the "volume by price" study, how can I set the volume based on real volume rather than tick data?
[2018-06-01 16:34:23] |
What symbol is this in reference to?
[2018-06-01 16:46:16] |
It's in reference to YMM18.
[2018-06-01 16:54:02] |
Therefore, there is nothing special to do. The volume profiles are based on actual volume. But do check this setting: Volume By Price Study: Volume Bar Calculation Method Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-01 16:54:41] |
I want to see the exchange volume rather than tick volume. And I don't know whether it's possible to change the setting on default tick volume.
[2018-06-01 17:02:49] |
That is what you are seeing and we do not know why you think otherwise. Here are the instructions for the Volume by Price study: Volume By Price Study: Step By Step Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-01 17:03:47
[2018-06-01 17:26:28] |
When I try to change the setting of the study of "volume by price", there is no setting on exchange volume. There is only setting on volume of ticks. And if you apply "volume by price" study on any symbol of CFD, it works. But there is only tick volume calculated on CFD, there is no actual volume calculated. So it means if we want to see the actual exchange volume on the futures, the default settings of "volume by price" should be modified.
[2018-06-01 18:40:41] |
When I try to change the setting of the study of "volume by price", there is no setting on exchange volume. There is only setting on volume of ticks. We do not know what you are referring to here. But none of this really is relevant.You said the symbol this is in reference to his YMM18. This is not a CFD. So it means if we want to see the actual exchange volume on the futures, the default settings of "volume by price" should be modified. No, this is not true whatsoever.
[2018-06-02 04:40:40] |
OK. I see.
