Date/Time: Mon, 20 Jan 2025 08:27:30 +0000
1755 - VbyP - Display Volume in Bars
View Count: 953
[2018-06-01 04:24:45] |
Acro - Posts: 441 |
Hi I've gone back to 1754 as the volume or whatever else is chosen (eg ask bid vol difference) does not appear to be "stable" in 1755 and also the size of the volume profile keeps changing radically by the second. By not stable, I mean that for example in 6E the difference between ask and bid at any price is generally in the range 0 - 200 but the VbP study will if left running start showing this in tens of thousands, which cannot be correct. If I change it to volume and then back to ask bid difference it is correct for a few seconds but then goes haywire again. Not sure what is going on with that calculation Date Time Of Last Edit: 2018-06-01 04:25:04
[2018-06-01 04:27:09] |
We will fix this now. There are significant performance improvements for TPO and volume profiles in this version.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-01 04:27:16
[2018-06-01 05:00:30] |
This is now fixed and we are going to be putting out version 1756 in about 15 minutes.
[2018-06-01 13:13:52] |
User182649 - Posts: 31 |
Just updated to 1756. Issue to be resolved.
[2018-06-01 13:52:24] |
User173602 - Posts: 16 |
Support, I D/L this version of SC (1756) and it no longer shows the VpB component of the Market Profile chartbook? Still shows in 1750 as I run two (2) copies of SC. One a reseller version and one I pay for directly.
SC_1750.jpg / V - Attached On 2018-06-01 13:51:07 UTC - Size: 470.67 KB - 278 views SC_1756.jpg / V - Attached On 2018-06-01 13:51:44 UTC - Size: 355.87 KB - 254 views Attachment Deleted. |
[2018-06-01 16:21:50] |
In response to post #5, provide that particular chart following these instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart Otherwise we cannot help with this. We cannot reproduce the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-01 16:53:25] |
Support, chartbook attached as requested.
Private File |
[2018-06-01 17:25:09] |
We see the problem. We are looking into it.
[2018-06-02 01:11:37] |
The problem with prior volume profiles not displaying in a chart, has been resolved. Update to the latest pre-release following the instructions here: Software Download: Fast Update The version is still 1756. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
